85PSI supply pressure is too high?
  • 85PSI supply pressure is too high?
    just found my water supply pressure is about 85psi. i remember it should be around 70psi. do i need a pressure regulator? thanks,
    Re: 85PSI supply pressure is too high?
    85 psi is borderline high. I would leave it. Keep an eye on it to make sure it doesn't go much higher.
      It depends on where in the "USA" you are. If you are within an area under either the UPC or the IPC you would need to regulate the pressure to below 80 psi.
        What's the UPC and IPC mean?
        I am in MA Boston area.
          UPC = Universal Plumbing Code
          IPC = International Plumbing Code
            They are the Uniform Plumbing Code and the International Plumbing Code which the majority of the United States use one or the other. Your State has its own Plumbing Code which says:
            (g) Excessive Water Pressure.
            1. When the municipal service or other water service source provides water to a building that exceeds 80 P.S.I.G., a pressure reducing valve shall be installed in the water main pipe at the point of water service entrance to the building. This is to reduce the water pressure to a maximum of 80 P.S.I.G. or less. This requirement does not apply where the water service pipe supplies water directly to a water pressure booster system, an elevated water gravity tank, or to pumps provided in connection with a hydro-pneumatic or elevated gravity water supply tank system.
              which range is a good water pressure range? around 50 psi as this valve's setting? http://www.homedepot.com/h_d1/N-5yc1...atalogId=10053
                All things being equal, I have always used 60 psi as my standard.
                  i probably would leave it alone if it was my house.if it was a customer i would recamend a prv.
                    Massachusetts has their own unique plumbing code, and by the way....no skin off my nose, but we know from our internet colleagues that the FINE for a homeowner working on their own plumbing has 3 zeroes in the number! SO for peace of mind, I recommend that you call a licensed plumber.
                      $000 ouch
                        I think he meant a three figure repair?
                        Home: make sure you get the right one to put in so that it doesn't destroy your water heater. Want to know which one is the right one? Well that info is part of the three figure repair price.
                          $000 is not a three figure?
                          Too late, this one is put in already: http://www.homedepot.com/h_d1/N-5yc1...atalogId=10053
