Can I solder a closed ball valve with water on the other side??
  • Can I solder a closed ball valve with water on the other side??
    I have two 1 1/4" ball valves that we left stubbed out as the supply and return for what was at the time my unfinished basement. I am now in the process of finishing the basement and wondering if it is possible, acceptable, or a good idea to try and sweat the manifolds for my basement zones while there is water on the other side of the valve?? Seems that the temperature will create a great amount of pressure and the presence of the water will make achieving the proper temperature very difficult. But draining the entire system is a real pain, so if there is a better option I would like to know.
    Thanks
    Sean
    Re: Can I solder a closed ball valve with water on the other side??
    You can see the ball valves in the bottom of the attached picture.
    Thanks,
    Sean
      Yes, it can be done.
      I just don't know if you can do it.
        To me it looks like you have some short pipe stubs coming out of the valves already...
        If stubs are there its easy
        I would just wrap the closed valve with a damp paper towel and solder away.
        You should try to find the guy that did the work..he did a nice job for you
          Yes it can be done. Just wrap the valve with a wet rag.
            sean, looks good. i think those stubs were not soldered, but just pushed in to allow for proper strapping?
            here's the method i use. most importantly, make sure there is actually liquid up to the valve. no air pockets an air pocket against the valve can create enough heat to cause a leak or worse a blow off
            so make sure that the valves have liquid against the ball.
            i would also heat from the copper tube and allow the heat to transfer up to the valve first. this will keep the direct flame off the valve packing and teflon seals. start approx 2-3 '' from the valve and allow the heat to travel up. as it gets hot, then move the flame onto the valve socket. keep the flame moving around just long enough to draw the solder up into the valve socket. use a dry rag to wipe any excess flux and solder. wipe the flux as it runs and without flux the solder won't drip down onto the tubing. makes for a cleaner looking job.
            post pictures of your finished work
            and most importantly, don't burn down your own house
            the guys at the station will never let you live that one down
              When I see pictures like the one of this guy's basement, I am so glad to be a carpenter. I mean, the most complicated thing I've done lately is a compound miter for crown molding. That guy's spaghetti of copper makes my head spin.
              Looks like a government regulation flow chart.
                If you're a little nervous about it, you can use heat sink paste and a wet rag.
                I get a little tense when brazing in a reversing or TXvalve. The heat sink paste is a little extra insurance.
                James
                  Rick is correct we left just slipped those pieces of pipe into the ball valves so we could clamp them, thus I will be soldering the valves themselves and not the copper stub outs. The fella who helped me accomplish the project is a friend from the firehouse and he is currently laid up post knee surgery, plus I hate to constantly bother him. Many of the joints in the heat system I soldered myself and I plumbed the entire domestic water system for the house in copper. My point being that I am just on this side of dangerous with a torch and some solder!!! We did not bleed the air from behind those valves but I can accomplish that fairly easily. So I am gathering that once the air is bled I can solder with just water on the other side.
                    Yes.
                      Looks nice and orderly to me, no spaghetti in there that I can see (most people I know would consider that a negative remark).
                        real nice job . wrap the valve with a wet towel
                          Rick,
                          Thanks for all the advise. Did it exactly as you advised and it worked flawlessly!!! I do not have my camera available right now, but I will post a couple pictures as soon as I can. Again, thanks for all the advise!!!
                          Sean
                            Yes, you can solder them as stated, but sometimes if the ball has water in it it may not want to heat up enough to create even heat to draw in the solder very well, or it may steam up and create pinholes in the cooling solder joint.
                              Wow Bob, you reeeeeally missed my point.
