Shower Valve Help
  • Shower Valve Help
    Its a 30-40 year old shower valve. The lever controls the water flow and the outer knob controls the temp. Any ideas would be nice Thanks Paul
    You can lose with me, but you can't win without me!.... PPI
    Re: Shower Valve Help
    Is this some kind of a contest? Do you want us to guess the manufacturer?
      Yea a contest! If you may have seen it before maybe you know who makes it. Your out of the contest for trying to be smart.
        Only company that would make something that ugly is Kohler
          I wasn't trying to be "smart" You were not clear as to what you wanted. So I asked
            i don't know but kohler is probably a really good guess just looking at the style
              Feel like pulling the stem?
              What're those buttons on either side of the plate screws?
                The only thing I could think of after reading is what can I do to get DQ...................
                  To remove and close water with flathead from valves inside of wall. Very odd!
                    That's it your OUT!!!!
                      Hmm. Well I don't think it's a Kohler.
                      That being said, I've looked thru all my books and can't quite match it.
                      Some come close, but not exactly. That's why I thought seeing the
                      stem might help.
                        Is this in a commercial application?
                        It appears to be a commercial valve of some sort.
                        Symmons, Leonard, Powers, maybe even an old Grohe.
                        The lack of markings on the handle is a problem.
                        If it was Kohler, their name would be all over it.
                        Pull the stem, post a pic. Inquiring minds want to know.
                          Personally, I would send those images to Kohler and see if you get a bite. I've seen a shower valve by Kohler that was SORT of similar and wasn't marked at all. I only discovered it was Kohler after removing the escutcheon and handle.
                          The age on that valve was also ~30 years old.
                            All I can say is Canada.
