Rigid Sump Pump
  • Rigid Sump Pump
    I had a 1/2 hp Rigid Sump pump installed about 5 months ago. Lately the pump is being activated every 15-30 seconds and is not draining the pit all the way to the bottom. It is winter here so all that is coming in is some ground water. This can't be right!
    Re: Rigid Sump Pump
    I am currently dealing with the same issue. My check valves are fine (I have a backup). It seems like the arm that triggers the pump to start does not stay in the "on" position.
