15SI tube cutter
  • 15SI tube cutter
    I notice on this tube cutter you changed the pin on the cutter wheel from threaded to push in style. Good idea but it still doesn't work. The pin still rotates and gouges out the formed stop. Possobly changing the material that the tool is made from is a better solution.
