Repair a tub
  • Repair a tub
    i have a fiberglass tub and walls and with all the shampoo bottles it there [one was a metal one ] it put a little nick in the bottom .
    is there a repair kit to fix this
    Re: Repair a tub
    Hello, Yes, actually if you know any body shops they will recommend a fiberglass bondo. I have used a brand called "Evercoat Glass-Lite" It is a waterproof fiberglass filler. Then naturally you would have to spray the "gelcoat" color finish on it. Wet sand to smooth finish. Hope this helps.
    GregC, President/Founder of Quick Belt System
    www.quicktoolbeltsystem.com
      Re: Repair a tub
      i just asked Red Green and he says Duct Tape! one of my favorite shows!!!
      just google fiberglass repair kit.
      the only dumb question is the one that is not asked!
        Re: Repair a tub
        when they would come on the job in finish and touch up the tubs, they would lock the door behind them.
        you could never miss the smell of bondo in the morning
          Re: Repair a tub
          i thought for sure you would know what to do
            Re: Repair a tub
            nomally i have my customers get in the shower and point it out.
            something tells me that won't work with you
              Re: Repair a tub
              you know rick i was going to PM you about this but you said no PM
              so have you ever fixed a fiberglass tub before or should i ask Joey for help
                Re: Repair a tub
                napa. breid..............
                  Re: Repair a tub
                  I've seen a few fiberglass tub repairs and some of them were on the skid resistant surface on the bottom of the tub. A professional repair done flawlessly. Rick is right about them locking the door. When the company did the ones I saw, the technician wore a suit and a respirator and had a ducted fan to get the fumes out of the home. The gel coat is an epoxy paint like Imron (no longer made) and you don't want any of that in your lungs. If your tub is a Lasco, you can contact them for referrals.
