K750 drain machine
  • K750 drain machine
    I have a k750 and I want to remove the guide tube assemble. My question is: how do I remove the grease fitting catalog # 89815, is it threaded so that it would spin out or do I need to remove it to remove the guide tube.
    Re: K750 drain machine
    Actually you do not need to remove the grease fitting to remove the guide tube on the K-750. If you remove the three ¼”-20 X 5/8” screws the guide tube assembly will slide off over top of that grease fitting.
    As for the grease fitting it is driven in to place, not screwed.
    I hope this helps.
