dripping sound in wall when water is on
    Re: dripping sound in wall when water is on
    Originally posted by Chemeng View Post
    Possibility:
    Expansion and contraction of pipes (both copper and ABS/PVC) rubbing against wood studs/joists can make a similar noise as water dripping. Happened in the last house I lived in. Drove me nuts, but not nuts enough to tear the plaster down and investigate.
    I agree with this. We see this a lot. To figure out if it is this. Run hot water through a faucet near to where you hear the noise the most. Let it run for a good 8-10 minutes., If you hear the clicking noise, then run cold water through for about 8-10 minutes. Noise will most likely change. Then just run cold water for a while, and see if the clicking is there or as loud.
    "don't put that in your mouth, you don't know where it's been"
