Water Weight?
  • Water Weight?
    What's the weight and volume of a column of water 1" in diameter x 100' long?
    I forgot. If I ever knew.
    Re: Water Weight?
    it will weigh 34.04 pounds
    G3
      Re: Water Weight?
      G3
      Is that off the top of your head, from a pocket-guide, or formula you just know?
      Thanks.
        Re: Water Weight?
        volume of cylinder
        v=(pi)(r2)(h)
        v=(3.1415)(0.5*2)(1200)
        since the radius is in inches the height will also need to be in inches
        v=942.45 cubic inches
        one cubic inch of water weighs 0.0361 pounds
        weight = (942.45 cubic inches)(0.0361 pounds/cubic inch)
        = 34.02 pounds
        What did you come up with??
        G3
          Re: Water Weight?
          top of the head formulas that I know, I have always loved word problems and conversions. Had a couple of great chemistry teachers that made learning easy.
          G3
            Re: Water Weight?
            volume of cylinder
            v=(pi)(r2)(h)
            = 34.02 pounds
            G3
            Nice - WOW 0 WOW
            Your crazy smart
            Well. That's an answer for ya
              Re: Water Weight?
              not really, just something that I know a little about. Other things I know nothing about. Like I always say, "even the dumbest person knows something you don't".
              G3
              I don't know much about jetting, drain cleaning or women.
                Re: Water Weight?
                volume of cylinder
                v=(pi)(r2)(h)
                = 34.02 pounds
                G3
                I can't lie to you. I was on the phone and didn't even get started. I hope to learn this well enough to put in the memory bank.
                Many thanks.
                  Re: Water Weight?
                  If you are looking for psi at 100', then the constant for water pressure (PSI) is 0.433 lbs per foot. So if the water is fresh drinking water, and the column is vertical and equal to or more than 1 square inch area, the answer is 43.3 psi. Doesn't matter if the pipe is 1 1/4"d or 3'. A 1" diameter pipe is only .78539... square inches. 43.3 x .78539... = 34.00774..lbs.
                  34+ lbs is a good answer.
                  Go
                    Re: Water Weight?
                    Originally posted by Gofor View Post
                    The constant for water pressure (PSI) is .433 lbs per foot. So if the water is fresh drinking water, and the column is vertical, the answer is 43.3 lbs. Pure water weighs less.
                    Go
                    You gonna' take that G3?!?!? Go NASA on him!
                      Re: Water Weight?
                      JC you asked what the water would weigh, not how much pressure it would have at the base of a column.
                      Gofor is correct as long as it is at sea level and the water is at 72* F (if I remember that right)
                      That is all that I could add to it.
                      G3
