how to reuse this branch?
  • how to reuse this branch?
    Cut and capped few months ago and want to reuse this branch for one sink.
    Should I remove the entire pvc and reconnect a pvc to the cast iron part or can I remove the cap and join another pvc from there? how can I remove that cap?
    thanks,
    Re: how to reuse this branch?
    i would replace it. it looks to be up hill to cast. should be 1/4" fall down hill to it. check. that fitting that is sawed off is a pressure fitting. not meant for drains. they will not flow right. use drain fittings. if fall is correct you may use the old pvc. breid...............
