Gas Line and Fireplace
  • Gas Line and Fireplace
    I am in the process of some renovation to re-do a chimney and having a masonry fire place built. It will be for a gas log set. The question I have is when the 1/2" black pipe is run should it be wrapped where it passes through the side wall of the fire box?
    Thanks
    BTW the keyed gas valve will be installed in the floor.
    Re: Gas Line and Fireplace
    yes it should. the bricks and mortar/ lime are very corrosive to the pipe.
    2 layers of 10mil pipe wrapping tape with tape primer is good.
    not sure if you could sleeve it within a pipe. chances of a draft, smoke, fire
