Gas log install
  • Gas log install
    Solid brick on this one ! In CALIF. We have a lot of wood frame false chimneys with Metal bestos chimneys. On some I remove the cap flashing and plumb the gas from inside. did this on My own home. Question is there a code distance for the GAS KEY TO WHERE EVER ?
    Re: Gas log install
    tool, i thought it was 5' or less. i believe it is written to allow you to strike a match and be within distance to turn it on.
    of course it has to be in the same room too.
      Re: Gas log install
      I am leaving to go out of town this morning so I do not have time to look it up. That said, it would be 6' by default but I believe the UPC use to say 4'. Now Chapter 12 has been changed so much by blending in the NFPA I would have to look it up.
        Re: Gas log install
        What I may do is diamond cut out some fire box brick so I can have it on the face brick.
        then I'll re install with fire motar. I don't want it too much of a reach,for safety. thanks
