Okay to wet vent the w/c thru the tub vent?
  • Okay to wet vent the w/c thru the tub vent?
    Okay to vent my w/c closet like this? (Click on the thumbnail to see the larger image.)
    I'm trying to avoid some structural work by angling the w/c drain like shown.
    I'm in Los Angeles which is generally governed by the UPC.
    Re: Okay to wet vent the w/c thru the tub vent?
    Will it work? Probably.
    I would suggest calling a reputable licensed plumber for that type of work.
      Your talking a wet vent which is fine just not the way you have it drawn up (at least not in Ohio)
      ________
      GONG BONGS
      Mike
        ....(at least not in Ohio....or California)
          the way it's drawn is legal under IPC, as long as that flange would be allowed by the inspector, but you're not in IPC land.
            Thanks everyone for the advice. What do I need to change to make it meet code?
              I'm in IPC and I'm pretty sure that wouldn't fly here without a nondescript envelope carrying a a few dead presidents
                Wouldn't fly in Minnesota. You can't have a flat vent untill it's 6" above the flood level rim of the highest fixture on that branch interval. You also have to have the wet portion of the vent oversized by one size. (Here in Minnesota). So, if you're wet venting into a 2" vent, the line would have to be 3".
                Although what you've drawn would function just fine for the most part.
                  That would pass in michigan.
                    It passes anywhere wet venting is allowed as long as the vertical vent section is 2". There is nothing there that is a flat vent. It looks a little odd, but it meets code.
                      Doesn't the IPC require upsizing the small portion considered the wet vent?
                      Thanks.
                        If the tub trap is 1-1/2" then having it 2" is upsized. Am I right?
                        It wouldn't pass here because the 3"x2" wye is on it's back.
                          Let's all get confused! Interpretations vary of course but my understanding is that the wet vent begins at the outlet of the 2" combination and must be upsized to the downstream branch.
                            that vertical only needs to be 2" if its got a lav on it. The fixtures need to be on the same plane so that 3*2 should be horizontal. otherwise its just common venting two floor mount fix
                              Yes that's true BUT why is the vent 2"?
                              It could be 1-1/2" if it wasn't wet venting the WC.
