increasing water flow on 1.6 WC
  • increasing water flow on 1.6 WC
    How much can you really increase the water flow per flush on a 1.6 flush?
    I know you can manipulate the flapper so it stays up longer to increase the flow but how much does it really increase?
    Camered a lateral at a bank today thats been having reoccurring clogs the past couple months. Found a couple minor offsets in the 113' run.
    Never had a back up in 13yrs. Last year switched from 3.6gal to 1.6gal.
    Cost to dig up HUGE$$$$ due to the set up and if I understand correctly they plan to renovate/move in the far distant future. I suggested to switch back to 3.6 gal as the low flow is certainly a contributing factor as well as lateral that is not 100%.
    But their Plumber is only going to manipulate the flapper (I assume styrofoam) he thinks that will significantly increase the flow. I think it will only add another 1/2gal or so?????
    Re: increasing water flow on 1.6 WC
    While I'm at it:
    How the he11 do you spell the past tense of camera?
    I always spell it camered. I don't think a past tense version of camera even exist?
    Your up Joey, what do you think?
      thats how i spell it i heard scoped the other day since then i say i scoped the line. its according what kind of wc it is sometimes you can remove the water saver flapper and put in a korky or blue coast master and they will flush alot better but watch the water level cause if too much it will double flush. but i find in more cases than not it will help tremendously.
        Experimenting with an adjustable flapper with float can help alot depending on the toilet. Also, the 1.6 pressure tank flush toilets can solve the problem sometimes.
          re toilet; depends on the tank, some you can get a lot out of. You can glue an extension onto the overflow tube to bring it up to just below the handle hole, then adjust the float and get some more that way too.
          re grammar; camera is a noun for the rest of the world, and nouns don't have tenses. I like 'video inspected.' 'Scoped' is pretty good too. I sometimes use 'camera'ed.'
            How about a power assisted flush toilet?
            Grammar: how about using the right word to begin with "you're" I know that is probably pointless to point out.
              i use "cameraed" too.
              joey approves
              but it's not actually a real word
              good luck finding a 3.5gpf.
              most toilets tend to hold more water in the tank than what actually flushes. trying to get the bank customers/ employees to hold the handle is the best bet, but the most difficult option.
              sometimes a swap in the flapper will help, or as alex mentioned, raising the overflow level will give a longer flush.
              pressure flush only help with the short runs, not the long runs. 1.6 gpf is not much water to push out 113'. biggest problem is that you only have toilets and very little sink use. no showers or laundry to help purge the system.
              probably more ladies that guys with that extra wipe
              so the 3.5 will help mask the sewer issue. but so will double flushing.
                I think Canada still has the 3 gal tanks.
                You can lose with me, but you can't win without me!.... PPI
                  bingo.
                    Note to self: When asking a question 'bout gramer all ways get me punkshoeation and speling write.
                      i usually write something like "ran camera X'. camera showed (belly, break, roots, etc) at X' "
                      camera can be used as a verb in this context. this becomes part of the venacular of the trade. so cameraed would be acceptable. camera'ed is a contraction and i don't see it fitting. but that's just me.
                      steve
                        I was wondering about that too. I chose to just use the word televised. As in, "I televised the drain and discovered a blockage consisting of vampire teabags and condoms. Have a nice day."
                          It depends on the water closet. Often I find a double or triple flush with a flapper manipulation.
                          Toto Caruso is a great flushing water closet. To turn it into a true 3.6 gallon flush the ballcock and flapper needs to be changed.It is a continous flush and has enough force to allow the proper travel distance.
                          How about video inspection of existing lines or camera existing lines.
                            Often lowering the tank water level in an attempt to stop the wrong flapper from causing the toilet to double flush will result in very poor flushing performance.
                            As Plumb4Life stated playing with adjustable flappers is a better approach...
                            411 Plumb Appliance Stimulus Package
                              how about "videod line"?
