Identify this
    Re: Identify this
    Originally posted by rich34232 View Post
    Leave your camera in the drain and use an electrical snake . I bent my end so that I can push it in and twist it to grab and pull the item back. I think electricians call it a fish tape. Mine is 25 feet long.
    Great idea ! Also epoxy a magnet a couple of inches in from the Hooked end. Happy fishing.
      Re: Identify this
      You need my micro drain with laser cutter prototype. Just don't hit the stack lol
      Seattle Drain Service
        Re: Identify this
        Was this in a private home, or some type of commercial office/building?
        To me it looks like it might be a "Dental Hand Piece"
          Re: Identify this
          If it is, I don't want that thing anywhere near my mouth now
            Re: Identify this
            Originally posted by plumberscrack View Post
            OK i'll bite...what's a Matterrod?
            Nothing whats the matter with you? Lame but I had to do it
            Rod
            http://unclognh.com
              Re: Identify this
              OK ,What does the rest of Your sign read. Don't work harder -----
                Re: Identify this
                Make a hook or loop and have it sticking out of a piece of PVC with the cable comming up inside ... Use it like an animal Noose
                Most likely a meth pipe I get them all the time :-(
                Dave
                • #23
                  Re: Identify this
                  [QUOTE=NoeEttica;283682]
                  bill, this is what i tried to explain to you yesterday, but with a piece of pex instead so you can make the closet bend and san tee
                  • #24
                    Re: Identify this
                    What exactly are you proposing?
                    Ok, so I use a piece of say 3/8" PEX with an electricians fishtape inside. On the end of fishtape I make a hook. I push PEX up to object guided by the MicroDrain and snatch it with fishtape? Then lock it to PEX while pulling back?
                    This sounds like some medieval vascular surgery
                    • #25
                      Re: Identify this
                      Locate it, brace the stack, cut it with a sawzall, grab it, put it all back together.
                      Rinse, repeat.
                      • #26
                        Re: Identify this
                        very close bill
                        a snare would be with a piece of 1/8'' aircraft wire with a loop that's guided through the pex tubing. problem is you will need to lasso it and that might be difficult.
                        the other way, better way is to slide a fish tape through the pex, heat the end and make a nice loop that you could then hook the item and slide the tape back tight to the pex, then you could hook and grab the mystery item
                        • #27
                          Re: Identify this
                          Rinse, repeat.
                          problem is the pipe is located in the apartment below and the cabinet would have to be removed from the wall.
                          i say snare it and videotape it with the microdrain.
                          if it drops, you grab it at the basement or slab.
                          the management company needs to know the options and what might be involved if all else fails
                          • #28
                            Re: Identify this
                            Originally posted by Mr Slate View Post
                            This looks kinda like a hypodermic needle to me. I have seen them in toilets before and caught in stacks in cast. Dam Meth Heads
                            Yup, syringe is what I see too. Actually as odd as this is, with the bent head on it it almost looks like a syringe the orthodontist gave me when I had my wisdom teeth removed to flush out the sockets.
                            http://www.net32.com/images/endodont...yringe-412.jpg
                            That's a picture of it. I think that's what is in your drain.
                            Either that or some sort of skinnier needle with a bent metal part.
                            • #29
                              Re: Identify this
                              I dunno what it is, but it looks pretty easy to hook out of there and find out;
                              1/2" cable, big open softish wire spiral cone retriever, shove tool in first, stop short, put cam in behind, get a few winds of the spiral around it, pull cam back out of harms way, yank her back and find out what it is.
                              • #30
                                Re: Identify this
                                The new lighted tampons
