Here is one for you math nuts
    Re: Here is one for you math nuts
    Hopefully I changed that before anyone noticed
      70.71 feet of head, (Fresh water: 0.43 psi per foot of rise), 70 x .43 = 30.1 psi,
      angle caculator, http://www.csgnetwork.com/righttricalc.html
      psi per foot of height, http://wiki.answers.com/Q/How_much_d..._vertical_foot
        devine is right
        sin A = a/c
        sin 45 = a/100
        0.707 = a/100
        a = 70.7 this would be the height of the 100 foot pipe on a 45 deg. angle
        70.7 feet x 0.434 = 30.68 psi head pressure
        I did not see the 4" in the original post, as long as the ID of the pipe was over one square inch is all that matters.
        Now if you are wanting to know how many pounds of pressure the clog is holding back we have to look at the area of the pipe.
        ID of 4" sch. 10 (20 is a little odd) is 4.260" (steel pipe)
        area is 14.25 square inches with 30.68 psi is 437.2 pounds at the clog on the bottom.
        Head pressure is the pressure it takes to push water to a certain elevation and nothing more.
        G3
          G3, I havent looked at my tables but I would have to say I think you nailed it. You get the prize
            Originally posted by devine plumbing View Post
            assuming the water is 60 degrees farenheit its specific gravity is 1
            p = .434 x 70.71 x 1
            p = 30.688 psi
            that formula seems much easier. Thanks
            good for you devine . I didn't see mr. " call a plumber giving an answer !
              Thanks guys. I'll post more about it once I confirm it's sch 20 pvc.
              Long story short, what a cluster f#%k I was busting the crap with my bare hands.
                Those figures will be pretty close no matter what the wall thickness of the pipe is.
                If you are going to knock out the clog at the bottom of the pipe be sure to set up the video camera, it will be a goodun to watch fer sure.
                Need to be careful that thing will unleash on you like a cannon. Can you snake it out from the top, would be more safe I think.
                • #23
                  You can estimate this quickly, just from stuff you probably remember, and the answer will be close enough for about anything.
                  sin(45) = [square root of 2]/2 = 0.707
                  So, 100 feet of pipe at 45 degrees =70.7 feet high
                  1 standard atmosphere is about 14.7 psi.
                  1 standard atmosphere is also about 34 feet of water column.
                  70.7/34 = 2 with a remainder of 2.7... call it about 2.08
                  2.08 x 14.7 psi = 29.4 + about 1.4.... call it 30.8 plus or minus a little bit for guesstimating.
                  It's cheating if you have to look it up .
                  Btw the size of the pipe has doesn't have anything to do with it.... pressure is normalized to area... i.e. pounds per square inch. That's why you can measure pressure in height of fluid column... for instance feet of water, inches of water or inches of mercury.
                  • #24
                    Originally posted by jcsplumbing View Post
                    100% positive?
                    Thanks.
                    J.c.
                    i'll explain it to you, daa !
                    • #25
                      Explain it to me Tooly Tool.
                      How does a the leg of a right triangle with a hypotenuse of 100 equal 50? Gene states the 100' line is on a 45 degree angle, we azz-u-med he is dealing with a right angle equation making the other angel 45. Legs have to be the same.
                      daaa....
                      • #26
                        daaa....
                        If the run is 86.6ft. 100*100 = 50*50 + c^2, c = sqrt(10000-2500) = 86.6.
                        • #27
                          I think I edited at the same time you were posting.
                          • #28
                            Originally posted by NHMaster3015 View Post
                            If the pipe is 100' long ( stand it up, vertical ) then at 45% it would be 1/2 that or 50'
                            No, the others are right, the sine of 45deg = .7071 so a 100' pipe at 45deg would go 70.71 ft out and 70.71 ft up. Sin = opposite side of the triangle/hypotenuse with the hypotenuse being 100 the opposite side, or the rise, will be 70.71 ft.
                            • #29
                              Probably, I new you wanted an isosceles triangle like Gene said, I was just being a wise-***.
                              • #30
                                Wouldn't want it any other way...
                                Learnin' in N.C.
