Here is one for you math nuts
  • Here is one for you math nuts
    A 4" pipe is set at a 45 degree angle,
    is 100' long,
    is full of water,
    and has a clog at lower end.
    What would the PSI be at the point of the clog?
    According to my math the clog would be holding 453.071 pounds worth of head.
    What would that be converted to PSI?
    I tried to convert it, but I only have 10 fingers and 10 toes and I lost count at 19
    Re: Here is one for you math nuts
    You have 50' of head pressure.
    411 Plumb Appliance Stimulus Package
      is 100' long,
      is full of water,
      factor in the size of the clog displacing the water. water weighs 8.33 pounds per gallon. forget it. Math sucks
      Rod
      http://unclognh.com
        wrong!
          What do you mean? I'm confused already
            p = 0.434 h SG
            where
            p = pressure (psi)
            h = head (ft)
            sg = specific gravity
              If we use the pythagorean theorema^2 + b^2 = c^2 and the pipe is at a 45 degree angle making a = b or 2X^2 = 10000
              x^2 = 5000
              height = 70.71 ft
              Now convert height into mm using the following conversions
              70.71 ft x 12 in/ft x 25.4 mm /inch = 21552.408 mm
              convert mm H20 to mm Hg using the specific gravity of mercury 13.6
              21552.408 x 1mm Hg/13.6 mm H2O = 1584.736 mm Hg
              1584.736 mm Hg x 1 atm/760mm Hg = 2.085 atm
              2.085 atm x 14.7 psi/1 atm = 30.650 psi roughly
                Originally posted by NHMaster3015 View Post
                p = 0.434 h SG
                where
                p = pressure (psi)
                h = head (ft)
                Assuming the water is 60 degrees Farenheit its specific gravity is 1
                p = .434 x 70.71 x 1
                p = 30.688 psi
                that formula seems much easier. Thanks
                  21.64 psi
                  I believe I'm incorrect on this calculation using 50'. Others double check please as I need to know.
                  After further thinking I believe it would be 30.61 psi.
                  Your hypotenuse is 100' at 45 degrees. Azz-u-ming it is a right triangle (probably not with a different degree, but who knows???) then your two legs would be an equal 70.71'.
                  That would give your rise leg a distance of 70.71' from the starting angle. 2.31 vertical feet equals 1 psi. 70.71/2.31= 30.61 psi.
                  EDIT: Devine beat me to it.
                    If the pipe is 100' long ( stand it up, vertical ) then at 45% it would be 1/2 that or 50'
                      100% positive?
                      Thanks.
                        need to know diameter of the pipe!
                        G3
                          I'm sticking until taught otherwise.
                          Willing to learn though....
                            G3
                            4" sch 20. ID unknown
                            OD is same as sch 40. obviously ID of sch 20 is slightly larger but I'm just trying to get a rough idea so go with sch 40 ID of 4.026
                              G3
                              Shouldn't matter, right?
