Which is best tankless water heater?
    Re: Which is best tankless water heater?
    Originally posted by rich121 View Post
    I have read the bad and the good...which does make it confusing about purchasing a tankless heater, so what do the experts think?
    I am in the middle of a complete remodel of my home...wiring, plumbing etc.
    The tank would be located in the basement and in the same place as the old gas water heater.
    I have 2 bathrooms.
    Suggestions of brands and models would be greatly appreciated.
    Rick
    Rick,
    Save your money. Or if you insist on wanting to spend a bundle... check out the new heat pump water heaters. Not great on recovery in gallons per hour, from what I hear, but they are relatively economical to operate.
      honestly unless you need the room in your basement, you're spending a lot of extra money with no return on your investment.
      rick[/QUOTE]
      Well put Rick
        Has anyone on here installed one of the heat pump water heaters? If hot water is generally used once a day for the most part like at our house, it might be more economical, but is it economical enough to justify the higher cost?
          If you are looking to do a central water heater, I would stick with a tank. They are so well insulated these days there are very little standby losses.
          I am going to install tankless water heaters in my house, but I will have 3 of them. They are installed as point-of-use in order to save water. I am on a well and it often runs dry if water is being wasted. (running the tap, waiting for hot water)
          It would be much cheaper to run a central water tank, but it's the wast of water that gets me. So instant hot water, less then a few feet from the tap/tub/shower.
          Like someone said, save your money and buy a TV instead.
            If you have not installed tankless heaters yet have you thought of running a return line on your hot water side to your water heater ??? just A thught
            SMELLS LIKE $$$$$$ TO ME
              I think that for a tankless water heater the best way to go is a pot on top of the stove.
