WHY shower handle leaks water???
  • WHY shower handle leaks water???
    i have an old 3 handle setup and put new washers in 2 day and i have water leaking out of hot water handle? ive replaced washer and never
    seen this anyone know why>
    Re: WHY shower handle leaks water???
    There is a packing of some sort around the stem. It often does not need to be replaced, but you should grease the stem, and try tightening the packing nut a little bit;
