Gas union question
  • Gas union question
    I have another question. I had to replace my wh. I have a union right after my shut off valve for the line going to the wh. After I put everything back together, I leak checked it w/ windex(this is what a local guy told me to use) I have no bubbles forming, but every so ofter I'll sniff check that union and it will smell like nat. gas for the first sniff and then I can't smell it after that. Could it be that with the 59yr old valve right there that maybe I'm smelling it? Any suggestions?
    Re: Gas union question
    i'm not sure if windex will even bubble. doesn't seem like it would. either get a small bottle of leak detector, or use soap.
      I am not sure about windex but some water and dish soap mixed in a spray botle works ok but I would check the shut off valve also.Thanks good luck
      SMELLS LIKE $$$$$$ TO ME
        i've seen people use windex. but you have to be careful if it contains ammonia. this will corrode stainless flex connectors.
        a soap test is the best way to go. a sniffer can and will pick up anything that's combustible. if the old valve is a plug style valve. they will and do leak if not properly tightened and greased.
        chances are a $10.00 gas ball valve is the best fix. make sure the valve is rated for gas. most are now. check for the cga stamp or the aga if it's old stock.
