Primer Line Overflow in basement
    Re: Primer Line Overflow in basement
    Originally posted by Chemeng View Post
    Edible oil will go rancid and smell after a while.....water is cheap!
    Then don't put edible oil in there.
      What oil are you talking about? I thought you meant vegetable oil.
        I will default to you to determine the best oil. Viscosity, type, etc. as you are a chemical engineer and would honestly probably have a more educated and broader expert opinion than myself.
          I've been told mineral oil works well
          And yeah $50 is the cheep one. Perfection is expensive
            See the little nut under the faucet, that's where the clear pipe is connected to keep the trap primed.
            also that is a compleat cross conection of the patable water line to the sanitary line with no check valves alows bacteria and all that back into your potable drinking water not to menchin that setup is agenst coed
            SMELLS LIKE $$$$$$ TO ME
              thats why your a Chemical Engineer and most of us are licensed plumbers. not saying that to be meen just you didnt go thrugh aprentiship and study the plumbing coed like us .
                I am in Canada, not the USA. It is code here.
                • #23
                  That thing costs 50 bucks!
                  soo???? Think the last one was $45.00 It is what it is !
                  • #24
                    I was seeing a coed,then the wife found out !!!
                    • #25
                      Here is a photo of my clear poly tube for the floor drain pipe (not hooked up since I and A/C and a condensing furnace which fills the trap summer and winter). It is how it's done in Ontario (around Toronto anyway). This house was built in 2007 and was inspected and passed.
                      • #26
                        We go 1/2" not 1/4" TAKE THAT!
                        • #27
                          ummmmmmm.........ok...........
