Primer Line Overflow in basement
  • Primer Line Overflow in basement
    Hi folks, I'm hoping someone could help me out. I'm having an issue with the primer line (I think that's what it's called) overflowing. As the water flows down from the laundry tub faucet upstairs, into the two black tubes in the basement floor, it trickles out over the two black tubes and spills onto the basement floor. When I shut off the faucet upstairs, the water then drains down the black tubes.
    It seems like the flow is too fast for the black tubes. Was this setup installed correctly? We just moved in a week ago. The house was built in 2006.
    Please see pic attached. Any help is appreciated.
    Thanks!
    Re: Primer Line Overflow in basement
    Thanks!
    This is either a joke or I don't understand what your picture is. Those two black hoses in the floor should not be connected to your DWV system at all.
      Hey Mark, definitely no joke. I'm not sure what those hoses connect to. They just go downwards into the concrete.
        The opaque tubing appears to be some sort of supply lines and the black tubes might be sleeves for the opaque tubes. Do you know what the opaque tubes go to and can you shoot a better overall picture?
          What You posted is a DIY Illegal waste line. Please call a plumber for proper repair!
            id love to see pics of this laundry tub/sink particularly the drain.
              Apparently, I think this is how we do things in Canada:
              http://www.terrylove.com/forums/show...ht=primer+line
                Looks to me like someome tried to make a trap primer
                ________
                TEEN VID
                Mike
                  Wow, that is horrible.
                    That is a trap primer set up. I had a house built in the 70's same system (but no black pipe just the clear). I now have a house built in 2007...same setup (just clear pipe). When the laundry tube is used, it feeds water to the trap in the basement floor.
                    How else would you propose to do this? I'd like to know. (besides filling the floor trap up every fews weeks with a pail of water).
                      http://www.plumbersurplus.com/Prod/P...ve/39422/Cat/5
                      I use something similar to this. Never seen a valve with a trap primer built in.
                        That thing costs 50 bucks!
                          Light oil. No evaporation.
                            See the little nut under the faucet, that's where the clear pipe is connected to keep the trap primed.
                              Edible oil will go rancid and smell after a while.....water is cheap!
