Bad ABS or bad glue?
    Re: Bad ABS or bad glue?
    rarely see pvc dwv. i've come across my fair share of the bad abs pipe. it's such a clean shear that most of it doesn't leak bad enough to show up.
    never had an issue snaking abs with both drum machines, sectionals and jetters. the older pipe was solid core and newer pipe foam core. same as it;s pvc counterpart.
      WE ended up repairing all of the broken pipe/fitting problems with rubber no-hub fittings that clamp on. They are flexible enough to get in the tight spots between floors where this keeps happening. Sure gives a good test to working in a tight spot , because there is also the hot and cold copper in there too all jammed in a 12 X 14 area between the first and second floors. Thanks again for all the info and help.
