rough in
  • rough in
    Can a rough in a basement for toilet, sinc and bath all connect to the same pipe? Especially if the pipe was originaaly installed as basement drainage for a sprinkler system?
    Re: rough in
    sure
      Re: rough in
      drtyhands is pulling your leg
      here is the real scoop:
      the "Rough in" is for the second, third and above floors also known as the"high in".
      "Set in" is for the main floor and
      "Dug in" is for the basement.
      If you hear anything different then you are not getting the story straight.
      At a specified point in the house all of the pipes come and join together called a meeting point, usually found in a "conjunction vault".
      and one question "zinc"? Do you mean sink?
        Re: rough in
        The "rough in" is for the second, third and above floors also known as the"high in".
        "set in" is for the main floor and
        "dug in" is for the basement.
        And one question "zinc"? Do you mean sink?
        and how would you know this??
          Re: rough in
          You mean you don't?
          "Everything is funny as long as It's happening to someone else! WILL ROGERS"
            Re: rough in
            You mean you don't?
            That's not an answer! We're waiting
              Re: rough in
              i put a out house in the back yard and i found a pipe that went to my pool from the pump house . would this be a good pipe to tie into
                Re: rough in
                Um really?
