Old buried well? Urgent help needed!
  • #46
    Re: Old buried well? Urgent help needed!
    http://www.popularmechanics.com/home...umbing/1275136
    http://www.wellowner.org/
    Here is a good read.
    • #47
      Originally posted by MikeD1980 View Post
      from nationaldriller.com
      Deep well jet pumps are not limited by atmospheric pressure to 25 feet of lift. A good deep well jet can pump water from as deep as 200 feet.
      When the well casing is four inches or larger in diameter, a double-pipe system normally is preferred. Where the well casing is smaller than four inches in diameter, a single-pipe deep well injector can be used.
      sorry, i am a "google-a-holic"
      Can you put up a link? You are misreading something about the casing.
      The Driller is a national publication. Those are not Michigan rules. Go though some well logs. Look at all the 2" wells in Michigan. There were millions.
      • #48
        http://www.nationaldriller.com/Artic...00f932a8c0____
        • #49
          since it is double pipe, has to be at least 4". if it were smaller then 4" it would be a single pipe.
          • #50
            It does not say it has to be 4". Again, in Michigan a 4" could never be hooked up legally to a jet pump.
            • #51
              I wish you luck with your project.
              BTW, the well we replaced were because of township "point of sale".
              • #52
                not now it can't be used. but obviously in 1965 it could be, and has been working fine for 45yrs. current pump is a 2001 so it has been going strong for 9yrs.
                If it ain't broke, don't fix it!
                and according to MI code it is perfectly fine to keep using that set-up and is up to code, until a major repair is made, THEN it will have to be upgraded.
                • #53
                  IMO, you are arguing against your best interest. Why wouldn't you want the seller to drill you a new well and pumping system
                  How do you know it is a well and not a sand point?
                  Let it run hard for a day without turning it off. Then take a 5 gallon pale and check your GPM. I would like to see about 12/18 GPM for a modern home.
                  • #54
                    No one found the stick thing funny ...... tough crowd.... I am going back to the drain cleaning forum, you experts...
                    I thought it was funny!
                    I can tell you one thing I found when I was doing work in Michigan way back then. Practically nobody put in a four inch well and hooked up a jet pump. It was either a 2" well with a jet pump or a 4" well with a submersible pump. Then 5" became the norm with subs.
                    If you have a basement, the sand point well would be in the basement. A two inch well would be out in the yard.
                    Frequently asked questions about pumps and tanks.
                    • #55
                      Did you ever see a 4" below the ground?
                      • #56
                        Oh yeah, quite a few.
                        Until I was 18, I didn't know what a drill rig was. I always thought wells were drilled with a shovel. That's the tool my Dad brought me up with.
                        • #57
                          I learned something then. I have never seen a 4" below grade. I know they did not code like that. However, back then not all counties required permits.
                          • #58
                            Back then there were no permits, no well logs, no Health Dept breathing down your neck and no stupid fresh out of college inspectors telling you how to drill a well.
                            Yup, things sure have changed. Some for the better, but in my opinion, mostly for the worse.
                            • #59
                              1971 Cape Cod Mass. drove a 2" well point to 50' this way for our home. 71 ford pick up,
                              rear end blocked up . Had cut cut and welded an old rim with spacer,now I had a capstin winch. Tripod with block, 4" pipe full of melted lead tire weights [ 90 lbs.] ,from the bottom a 1/2" steel rod about 4 '. Drive cap with hole on 2" casing. Cape Cod is motley sand.
                              Did 6 more wells on homes I built. No well permit necessary.
                              • #60
                                Things have changed. Mostly for the good, IMO. I am a rules girl...LOL
