1.5" sweat
  • 1.5" sweat
    Hey Guys,
    New to the forum here. I have a large amount of rental property and have been doing the plumbing work myself for some time now. About 4 months ago I replaced a 1.5" Hoffman mixing valve on one of my boilers and I sweat it in. Everything has been holding up great and no leaks.
    My question is should I have brazed the piping due to the size and water volume demands? I used sterling solder.
    When do I braze as opposed to solder? And I will need different gas than MAP for brazing right?
    Thanks!
    **EDIT** Sorry I meant to post this in "Ask the Plumber"
    Re: 1.5" sweat
    Solder for your situation was appropriate. I like to "tin" the pipe on
    anything 1.5" and over. Silver solder requires acetylene to get the
    higher temp. About the only time I use it is underground or something
    weird like a t-drill connection (hardly ever, anymore) or HVAC line (which
    I don't do, anyway). The fact that it don't leak says it all.
      Re: 1.5" sweat
      Brazing is used on air conditioning & refrigeration. I used to solder 3 & 4" copper. And I used to braze 3 & 4" copper. I used to tin the copper on 3" and up when I solder. when brazing you need oxygen & acetylene for those big pipes.
        Re: 1.5" sweat
        Okay thanks guys. Sounds like I will be alright with the solder. It was the biggest pipe I've ever soldered so wanted to make sure that I wasn't supposed to do something different. I vaguely remember someone telling me about brazing and saw brazing rods at home depot so it got me thinking.
        What do you mean by "tinning" the pipes?
          Re: 1.5" sweat
          Tinning is cleaning, fluxing, heating and applying solder to the end of the pipe
          to be fitted. Completely cover with solder and wipe excess with a dry rag
          so the fitting can be affixed and solder as usual. This method assures even, consistent coverage of the solder in the joint.
            Re: 1.5" sweat
            That's interesting, I hadn't heard of that. I'll have to try it for practice soon, thank you.
            Out of curiosity, I went and picked up a cutting/brazing torch kit last night and ohhh man is that a big difference! haha.. . Now I need to find something to cut soon.
              Re: 1.5" sweat
              Yea you need to practice brazing or you will be cutting thru your copper pipes the same way.
                Re: 1.5" sweat
                It is possible to braze with MAPP gas.
                Brazing water pipes is only required when the pipe will be laid under a slab or if you are creating a tee fitting in the pipe wall.
