Boring for gas under slab
  • Boring for gas under slab
    Need to run at least 20 ft. under slab for gas line .I have a 2500 psi jetter 100 ft of 1/4" line
    can i use this and pvc to get through? Also looked at bullet mole. Maybe I can rent? Thanks open to all ideas. Tool
    Re: Boring for gas under slab
    We drill under county roads with a Ditch Witch Directional Drill.
    I think your plan will work. You will need water and maybe mix mud to keep your hole open.
      Sure,yeah,uh-huh,yup,you betcha,
      except I don't like doing it with a jetter.If you don't keep it moving fast enough your going to create a void in the soil of lord only knows what size.
      Slab?
      How are you going to get elbows on your sleeves
      How's your spring going
        Spring is duckey! Just did u tube bore it tool, looks good! Anyone use it?
          tool, are you allowed to run gas under a slab? hopefully it's an outdoor patio slab and not the living space
          my 50' section of hydro bore will easily drill a nice hole in 2.5' sections. problem with pvc is the hole will not stay straight as the plastic will veer.
          my steel hydro bore will stay much truer than any plastic can.
          of course the hydro drill will also do a good job, but is much more risky and labor intensive.
          with my hydro bore, the pipe can be pulled back with the bore head. depending on the pipe size and material.
            Would it help if he mix drilling mud to hold the hole open?? I have only used black polly (160 psi) but, we do go down 5 foot.
              Well ,they agree to go over roof [ flat ] and down.This will feed an outside fire pit and gas log for fireplace. The 2nd issue is the kitchen Island stove that needs gas. This is a concrete slab, only way is to bore under!
                You cannot run gas under the slab within the structure unless it is encased and vented.
                  Thanks Mark, Is the proper detail spelled out in the U.P.C. ? GOT IT THANKS GOOGLE !!
                    Re: Boring for gas under slab , Sealing the chase
                    Sealant of P.V.C. pipe chase under stove cabinet. My Guess is first using foam backer bead
                    in the pipe,chase void,and then using a polyurathene calk [ silkaflex] sound right? thanks
