You'llaugh at this. Pull odors from toilet bowl.
  • You'llaugh at this. Pull odors from toilet bowl.
    In the powderoom next to the front door is only a window - no vent fan.
    The window opens to the front porch where guests are arriving.
    I'd like to keep the window closed and pull air up the toilet tank overflow tube to pull odor from the toilet bowl into the holes of the flush rim.
    We have an old bonnet-style hair dryer, wide-neck funnel and adhesive-backed foam strip insulation sitting around.
    Using ductape, I sealed the funnel over the hair dryer air intake.
    Attached the hair dryer's 1-3/8s inch diameter hose to the funnel neck.
    The quiet hair dryer has three speeds which can adjust the gentle vacuum through the hose.
    Below the floor, the dryer would expel the air into the basement.
    I can run its hose up behind the drywall in back of the toilet.
    The foam gasket on the tank rim would make a good seal and also allow the lid to beasily removed.
    Can I saw a 90-degree \/-shaped hole at the top of the tank wall?
    The hair dryer hose could be inserted and silicone-sealed into the notch and pull air out of the tank.
    Now stop laughing.
    Thank you.
    Robert
    Re: You'llaugh at this. Pull odors from toilet bowl.
      There is a manufacturer that has a toilet that does that ... I can not remember who at the moment ... saw it at a trade show ... Dave
        Re: You'l laugh at this. Pull odors from toilet bowl.
        Why wouldn't You Put id a GOOD fan? Exhaust fans are measured in c.f.u. cubic ft . per minute. You want that high!And scones, Sound of fan and motor , You want that low! Also I have a specialty router set up to weather strip doors. Why not at this and a
        metal boot at door bottom. It will keep it Quiet!
          Now stop laughing.
          Thank you.
          Robert
          Robert what you want is a toto 300 bidet. This unit has a ionizer for oder control and works great. Most other toilet seat bidets have a carbon filter to remove odor. The toto works the best for odor control and cleans you very good also. I don't sell this model but I have used and installed quite a few. you will be happy with it
            Great idea robert, spend some $$$$$$$ Guy, what does this cost FLUSH?
              Originally posted by plumberscrack View Post
              I'm too embarrased to show my jury-rigging.
              Actually, have no way to post photos.
              Just picture a cracked toilet tank and flooded powderoom because some moron tried to saw his tank.
              (I'd do it with tank empty but am concerned if the tank could later crack from the weakness I caused.)
                The toto 300's are costly but he is interested in one anyway. What about you tool, when are you going to get one?
                As for the cost it has been a year or 2 since I bought a toto bidet so I'm not sure of the price
                  to answer your question, yes, you can cut a toilet tank with a diamond saw/ grinder. i've sawed a tank down before to fit under the banjo top. the hard part was the square tank hole i needed to drill.
                  now to answer your other question
                  your wife is actually going to allow you to jury rig a hair dryer/ fan into the toilet and plug it in while you do your thing
                  will it work, yes it will
                  will you be the talk of all your visitors yes you will
                  either do as toll mentioned with the fart fan
                  or do as i did with joeys approval install a toto bidet seat with the built in deodorizer/ incinerator. does it work joey tells me it does
                    Can't afford a Totoilet.
                    This is from an old plastic bonnet hair dryer, not the hand-held dryers, and parts already lying around.
                    The hair dryer motor unit would be in the basement with it's plastic tube running up the inside of the wall, then into the back of the tank.
                    So no electrical hazard and no noise. I'd also place it on a spare GFCI.
                    After her monthy party, could the Toto seat be easily removed from the powderoom and transferred back to the master bedroom toilet?
                    Too difficult to put in an exhaust fan. Also, it would have to vent under the front porch ceiling so odor could greet guests.
                    I'd rather pull air out than breathe ionized air.
                      When I first seen the thread title the first thought that came to mind was American Standard Vent-Away.
                        Porta potty on the deck! One with a sink! Jazz it up with candles,rug,linen
                          You could just install a fan lower down in the sidewall venting to the outside.
                            What deck?
                            Like the candles and linen!
                            Reminds me:
                            We.nt to a Symphony in the Parks concert.
                            Many were uncomfortable on blankets on the hard ground and some getting a little damp from the grass.
                            We arrive with our folding picnic table - like a large flat suitcase.
                            In two minutes the table and four seats is set up.
                            We take out linen table cloth, LED candles, wine glasses, silverware and linen napkins. Sit comfortably shaded beneath the table's umbrella and enjoy grape juice (I'm on call for medical transport) and cheese and crackers.
                            Then a short light rain from which we were protected.
                            We invited a nearby elderly couple to sit with us.
                            Everyone was envious.
                              You could just install a fan lower down in the sidewall venting to the outside. J.C.
                              Good idea!
                              But here it would vent at the arrivinguests. Also, a wall extends out next to the front door and creates a kind of pocket to trap air beneath the porch ceiling.
                              Also I'd have a problem getting wires through the insulated wall.
