Affordable snake for smaller lines ?
  • Affordable snake for smaller lines ?
    I'm looking for a small snake for doing the lines in my house. (i.e. washer
    drain, sinks tubs.) I've seen the ones that look like drills with a canister on the ends, Any suggestions ?
    As always thank you in advance.
    Chris
    Re: Affordable snake for smaller lines ?
    Just found a k35af for $199 or the k45 for $349 or with both cable for $415.
    Even found a k400 or k380 for right at $400 delivered,
    are either of these any good ?
    Thanks
      based on price and your needs. i would stick with the k39 auto feed. the k-45 is basically a newly designed motor.
      the k-400 or 380 is not your machine for tubs.
      key to longevity is taking the cables out after you're done and drying them and oil. don't install the cable til you're ready to use it again.
      my cables last a long time because of this practice.
