Proper way to do a smoke test for D.W.V.
  • Proper way to do a smoke test for D.W.V.
    Having trouble finding someone to do this. Can You help? thanks Tool
    Re: Proper way to do a smoke test for D.W.V.
    Interesting!
    Never heard of a smoke test.
    I had to plug all openings and fill with water all the way to the top of the roof vents.
      Big cigar and blow in the overflow in one of the toilets.
        Big cigar and blow in the overflow in one of the toilets. J.C.
        That is the standard Fartfan test.
          Was that you with the HairDryer? Did you get that madness going yet?
            Was that you with the HairDryer? Did you get that madness going yet? J.C.
            Thanks to PlumbeRick, my wife is afraid of a methanexplosion and hid it.
            Actually, I have not found the old hairdryer. With the vent holes I discovered in the Bemis toiletank cover, it should be even easier to connect a vacuum to it and try. I was planning to use a cigar in the bowl to see if any smoke was drawn into the rim holes.
              We don`t smoke test our DWV drains we air test them as we carn`t aford to waste water go to this web site and have a look www.plumtest.com.au
              Tony
                Originally posted by AFM View Post
                We don`t smoke test our DWV drains we air test them as we carn`t aford to waste water go to this web site and have a look www.plumtest.com.au Tony
                What pressure and how long?
                How long to pump up a typical DWV system to test pressure?
                  I have never done a smoke test, but local Wastewater districts will introduce smoke in nearby manholes if they suspect illegal sewer hookups in the area. They then just look for the buildings with smoke rising from the vents. Busted!
                    125 psi in Mass. 40 years ago , i remember. cold climates water test may freeze in winter!
                      Are you doing this for an inspection or trying to track down a sewer odor?
                      Drop a smoke grenade down the roof stack and blow air in behind it with a leaf blower. Don't over blow it or you'll push smoke all the way into the main.
                      You can find cracked stacks, broken vents and dried up floor drains with this method. You'll also know how long it takes the fire department to arrive after your neighbors see smoke coming out of the attic
                        an air test for waste and vents require 5 psi pressure. great since you can actually test an entire building from the lower level all the way to the roof. water test typically is limited to 30' as the pressure will get up towards 15# at the base.
                        we are required a 5# test or 10' of head or to the top of the roof vent.
                        the air test is the most difficult to find leaks on and requires the most work to perform. a water test can get messy, yet it's a simple test and simple to find a leak.
                        done both ways and i prefer water on new work and air on occupied buildings that a blowout could get wet and messy.
                          125 psi seems much too high.
                          Was that before PVC and ABS?
                          Seems a blowout could be dangerous, especially with so much air and its compressibility.
                          Can't remember at what pressure I had to test my black pipe gas line.
                          Had to hold pressure on the gauge for 24 hours.
                            125 psi 5 psi is what you would use on a MJ system. If it is plastic be careful if that s^*t blows up you could be hurt or possible death.
                            If you have access to someone in the HVAC biz they might be able to help with getting you the smoke bomb.
                            Last time I try to fix it myself. Next time I will hire a PROFESSIONAL.
                              WOOPS !! That's water {copper ]
