hey colegas
  • hey colegas
    how can i cut an 8 inches cast iron pipe
    Re: hey colegas
    If the chain on your snap cutter isn't long enough you could use a grinder or even a metal cutting blade in a worm drive saw. Depends on the location of the pipe and how much clearance you have.
      Re: hey colegas
      ill do all new is for roofdrains i think is in a warehouse but i dont know wats beter to cut it
        Re: hey colegas
        For you, I think a "hack" saw would be appropriate.
          Re: hey colegas
          Use an angle grinder with a cut blade and a mask.
