trickle faucet
  • trickle faucet
    I have a price pfister model f-026-4nyy kitchen faucet. I have removed the screen at the tip of the faucet and the pressure is still at almost a trickle. I check the water pressure coming off the angle stops (through the supply hoses) and it is great. The separate spray hose seems to operate at a decent pressure. Is there an internal filter screen? I'm guessing there is debris caught somewhere restricting the pressure. I can't find the internal screen...
    Re: trickle faucet
    Price Pfister .
      Re: trickle faucet
      More than likely there is a blockage of some sort inside the faucet. It could be in the cartridge, faucet body, hoses, or the diverter. Take it all apart and you should find it.
        Re: trickle faucet
        The restriction is in the cartridge. No visible debris blockage. Let you know after I replace it.
