Vent needed?
  • Vent needed?
    Older home has utility tub added in basement directly below kitchen sink. Kitchen sink 2" Pipe comes down the wall to 4" in floor. A plumber removed the clean-out to connect utility tub. Besides eliminating the clean-out (that I now need to clean the 4"). They also installed two automatic vents.
    I want to leave the sink but restore the clean-out to at least 3 1/2". I don't need any vent since the utility tub has less than 5Ft of pipe going to 4" pipe.. Correct?
    Thanks, Dennis... I'm septic & drain not a plumber.
    Re: Vent needed?
    The utility sink would be wet vented, so yes you will need a vent, and most codes do not allow you to use a clean out to plumb in future fixtures.
      Re: Vent needed?
      I don't think it is allowed to be plumbed into the clean-out fitting. Although the plumbing was done by a licensed plumbing company. I'll get the plumbing company that did the work involved and See what we come up with.
      Thanks, Dennis....
        Re: Vent needed?
        Thanks, Dennis....
        Just curious, other than its threaded plug, how can one connect to a female cleanout outlet?
        Yes, I would have opposed eliminating a cleanout.
        In the 3-inch vertical line from the second floor, I.nstalled a wide-sweep "Y" |r| with the cleanout exiting flush with the exterior siding about 30 inches above the ground.
        Makes for the easiest rooting jobs I havever done.
        Also installed an outdoor outlet near it for the rooter.
          Re: Vent needed?
          Originally posted by Robert Gift View Post
          Just curious, other than its threaded plug, how can one connect to a female clean out outlet?
          Yes, I would have opposed eliminating a clean out.
          Has a threaded bushing thats probably 3 1/2" since it was a 3 1/2" clean-out. The bushing looks older like the plumber installed a new sink and piping similar to what was there before he got the job.
          I'd guess one of those rubber donuts would make a connection. I've seen a donut connecting 4" PVC to 4" cast bell without a leak. High rough, at the wall and no leaks. I was surprised how it seemed to work well.
          I have a restaurant right now I keep telling the owner to have a outside clean-out installed. It is overhead in the basement, give me a break!
          Best, Dennis.....
            Re: Vent needed?
            ...I have a restaurant right now I keep telling the owner to have a outside clean-out installed. It is overhead in the basement, give me a break! ...
            What? And save bringing heavy rooters inside and downstairs and then hauling the filthy rooters back up?
            And miss the fun of pulling the dripping snake out above your head?
              Re: Vent needed?
              The really sad part is the clean-out cap is only two feet from the back wall and parking lot. A 45 and three feet of pipe would put it outside (brick wall but oh well). I had a plumber give him an estimate to do it and he didn't have it done so far. Ooops, I hope he can swim.
                Re: Vent needed?
                How unfortunate. (stupid)
                If I were there, I'd put in thextension myself. (First would check with the building department to see if there is anything prohibiting an exterior cleanout there.)
                Never had a problem chiseling through a double brick wall. Actually kind of fun!
