copper sulphate...two toilets?
  • copper sulphate...two toilets?
    My home has two toilets...do I need to do the copper sulphate root treatment through both of them to kill and keep roots away?
    Both toilet flush ok, but sometimes they back up if a lot of paper and waste is flushed so I periodically treat with copper suphate (ZEP root kill) which seems to work, but is twice as expensive to use through both toilets.
    Re: copper sulphate...two toilets?
    copper sulphate is for killing roots. your problem sounds like a toilet issue.
    when your toilets plug up, do any other fixtures also plug up like a tub or shower?
    chances are your problem is a poor flushing toilet and not a root issue.
      NO YOU DO NOT NEED IN BOTH
      TOILETS YOU HAVE ONLY ONE MAIN
      SEWER PIPE TO THE STREET !
      I DO NOT BELIEVE IN THESE
      PRODUCTS !
      IF YOU COULD SEE HOW FAST THE
      WATER AND SEWAGE FLOWS DOWN
      THE PIPE IT WOULD BE LIKE
      WATCHING CARS PASSING ON THE
      FREEWAY WHILE YOU ARE STANDING
      STILL !
      THAT IS WHY I ONLY BELIEVE IN
      THE " ROOT X " PRODUCTS BECAUSE
      IT FOAMS UP AND FILLS THE WHOLE
      PIPE ! PLUS YOU DO NOT RUN ANY
      WATER AFTER IT IS IN PIPE FOR AT
      " LEAST " FOUR TO SIX HOURS
      AFTER-WARDS
      TO GIVE IT TIME TO WORK !
      JERRYMAC
      E-MAILJERRYMAC777@GMAIL.COM
      FIRE SPRINKLER CONTRACTOR,
      SINCE JAN. 1989
        Actually, it seldom completely plugs up...and nothing happens to the tub or sinks... I just wanted to use something to keep the roots out as "maintenance." I already bought the "Root Kill" product, so will go ahead and use it. Should I put a cup or so in, flush, and repeat immediately, or wait a few hrs. between flushes? And, since both toilets go to the same pipe, I guess using just one toilet will work ok?
            rootx. rootx. rootx. "root kill" is NOT rootx. rootx works. breid.............
