American Standard Flappers
  • American Standard Flappers
    I ran into a couple A/S 1.6 toilets from the mid 90's in the last couple weeks.
    The one I saw today was a Heritage 2-piece. Parts diagram says it's # 738258-0070A
    Flappers are light teal with the float. They look like the coast flappers.
    The one I pulled out looked like it barely seated on the flush valve to begin with.
    The Korky 1.6 flapper worked fine, but I'm curious as to what others have done/used as a generic?
    I've seen the OEM flapper in the Hodes book, but $12 seems a little steep for a flapper.
    -Chris
    Re: American Standard Flappers
    Probably was a Coast that had faded due to chlorine and time.
    I like the Coast Flush Guard with the changeable inserts that
    work on a variety of standard size flush valves. Also the
    Fluid Master adjustable and they also have a 3" universal
    adjustable for the newer W/C's.
      I pretty much just use fluidmasters on everything. I do carry one of the great big ones for the kohler cimarrons.
