caulking
  • caulking
    What method do you all,use to remove old tub/tile caulking?
    Re: caulking
    I don't think there is an easy way to remove old caulk. I wouldn't bother with the caulk removers. They don't work well and then you have the chemical flying up in your face while your scraping. I start with a paint scraper and a utility knife cutting and scoring. Then finish up with a single edge razor blade in a very sturdy holder. You can try a heat gun if the caulk has not gotten too hard. That may soften it some but it's slow going.
      Re: caulking
      +1 for dig and scrape method with heat gun.
      Multi-tool with scraper attachment in some cases.
