Need replacement backflow valve
  • Need replacement backflow valve
    Evidently we need to find this exact same backflow valve or else jackhammer our basement floor to put a new one in. Can anyone suggest how I might track this down?
    Thanks,
    Lee
    Re: Need replacement backflow valve
    I would bust out the floor and put in a new valve.
      Thanks,
      Lee
      First thing to do is call it a backwater valve rather than a backflow valve as there is a major difference. The second thing to do is break out the floor and replace the valve rather than trying to fix it.
        Howdy there, my answer is going to be a lot longer than Ron's, but with roughly the same recommendation.
        It kind of Looks like a "Jumbo Mfg." brand valve to me. If it is, a replacement flapper is likely available from many plumbing supply houses in your area. Here's the link to the website of that particular brand.
        http://www.jumbomfg.com/product_cast...ter_valves.htm
        Jumbo valves not very reliable though.
        My Brother-in-law has one installed as part of a flood control system with a pump at his house. The flapper gets hung up very easily on waste/debris.
        For backwater valves only, I recommend J.R. Smith or Zurn brands. A LOT more expensive, but you have to remember that with plumbing, and especially with flood control, you get exactly what you pay for. Quality is proportional to Cost.
        Some questions about your situation:
        1. How old is the valve? How old is the house?
        2. Was it installed while you have owned the home?
        3. Has it been maintained/serviced while you have owned the home?
        4. Where in the basement is it located?
        5. What flows through the valve (all plumbing fixtures or only some)?
        6. Is the basement finished (drywall, flooring, etc.)
        7. Why was the valve installed? Were there sewer issues at this house before or problems with the city mains or both?
        Answers to these questions would help in both identifying possible brands of the valve as well as making recommendations for alternatives
        If you answered No to #'s 2 or 3, I would highly recommend replacing the valve.
        If you answered yes to #6, you have to consider how much of a gamble you want to take on having the basement flood before you can track down parts or whether or not the valve will hold even if you can find parts.
        Regardless, I agree with Ron and I would still recommend replacing the valve as yours doesn't look too reliable.
        You may luck out and find parts.....maybe.
        Your best bet at finding parts will be a local supply house that offers counter sales to the general public.
        Bottom line, if it were my house, I'd remove that valve without question or hesitation. I have nothing to gain ($$) by making that recommendation to you.
        There is a reputable forum member on here from OK screen name OkieBill. I would suggest getting in touch with him.
        best luck
        -Chris
          That's the more concise way to put it
