Pressure washer piping
  • Pressure washer piping
    im on a job where im piping out a 1500 lb pressure washer to 6 locations and tying into existing copper pipe [ thats what they want ]
    we are running sec40 black pipe and we are welding it
    what would you do
    weld the pipe
    thread the pipe
    or use something different
    Re: Pressure washer piping
    What size line are you running?
      sorry i forgot 3/4 and 1"
        Are you using copper pipe for 1500 PSI? How are you joining the copper or the steel? "standard" steel threaded fittings I don't believe are rated for that, neither is soldered copper. You can braze the copper, but then the pipe takes on the pressure rating of "annealed"....well under 1000 PSI.
          Correctly-rated-threaded galvanized and properly rated fittings.
          Welded stainless.... Maybe.
          No black pipe.
          Double check pressure ratings, temperatures, and waivers for the job.
            I remember doing some hospital work and the fitters were running a high pressure soap line 1'' black pipe. everything was welded
            the fitting are out there. I don't know that you call them.
              [QUOTE=where am i;302993]I remember doing some hospital work and the fitters were running a high pressure soap line 1'' black pipe. everything was welded
              Are you doing this with socket weld fittings ?
              just weld a nipple in to a coupling.
              if you are doing this butt weld
              maybe a thread o lets
                we use but welding and use the same for the fittings
