Galvanized Tee
  • Galvanized Tee
    Does anyone sell a galvanized tee fitting which is 3/4" at both ends and 1" in the middle. I have looked online as well as local stores and cannot find anything.
    Re: Galvanized Tee
    Yes it is called a "Bull Head Tee" and it is fairly common.
      Re: Galvanized Tee
      remember that the local retail diy store only stock the common stuff. the plumbing supply house is where you will find that tee.
        Re: Galvanized Tee
        Any good supply houses you guys could suggest here in SD?
          Re: Galvanized Tee
          Where in San Diego are you?
            Re: Galvanized Tee
            http://www.autorain.com/itemdisplay.php?sku=305-102
              Re: Galvanized Tee
              Scripps Ranch.
                Re: Galvanized Tee
                Scripps Ranch.
                I believe there is an H-D Supply in Scripps Ranch. They will likely have a $25 minimum and may ask if you are a Contractor. As an Engineer they should sell to you.
                  Re: Galvanized Tee
                  blue, did you have to bring up the galvanized tee for gas
                  didn't we have enough fireworks last night
                  if you need the tee, i can mail you 1
                    Re: Galvanized Tee
                    Thanks Mark - I will check that supply place. I guess they are associated with Whitecap where I have been buying stuff for the concrete part of the project. Some Sonotube I recently bought there had HD supply also stamped on it. Actually I'm okay with going to any part of SD to find supplies. There is very little available around the Scripps Ranch area. I recently visited a company to talk about a new design contract and there was a Ferguson plumbing supply place nearby and so stopped off and bought some of that pipe primer I needed. There seemed to have a good selection of fittings so I will stop by and take a look.
                    Rick - yes I see less activity on that thread . Actually I contacted one of our local plumbing inspectors who told me to use galvanized on the outside (above ground) for gas. Appreciate the offer to send me the tee - if I really cannot find it I will take you up on your offer.
                    I've completed all of the below ground and some of the interior pipe - I decided to do an intermidiate air pressure check and it held 10psi for 24 hours so I'm going to continue with the rest.
                    Ravin
                      Re: Galvanized Tee
                      Hey Guys - I got the fitting at Ferguson plumbing supply - at the xpress counter. http://www.ferguson.com/index.shtml
                      Thanks for everyone's help
