add zone or add valve?
  • add zone or add valve?
    we have two rooms are spare during the winter and nobody stay there. right now we only have one zone. thinking about add a zone for them but my friend tells me it may be ok to add a valve to adjust the flow to reduce heat loss.
    is that true or can we use valve to control the flow and make those rooms consume less heat?
    thanks
    Re: add zone or add valve?
    no, on a single loop system you can not just put a valve in. You need to split the loop and add either a circulating pump or a zone valve along with a thermostat. Not a diy job, call your heating professional.
      Agreed
