tankless water heater
  • tankless water heater
    it is not for me i like my regular gas water heater so im asking for some one else
    brand -Noritz
    is this better then a regular tank type water heater
    tis is for some one on Long Island NY
    Re: tankless water heater
    in indiana. NO. the only times would be if you need the extra room or like to brag. breid...............
      charlie, you know which way i swing
      why tankless over tank?
      that's the question you need to ask.
        i know its for my sister and this ts the way she may go ,so all i can say is i told you so
          charlie, either ask your sister what she plans on gaining with a tankless, or have her call me
          she should already know me from our family photo at the amusement park
          by the time i get done with her, she'll be in hot water
            i dont think she would be able to handle talking with you
            and she said it will save her money with her gas bill , now gas on long island does cost a lot so it might just help
                I look at my 32$ gas bill
                During the summer its the only thing gas more than half of that is meter charge and all kinds of taxes
                Say my gas is 15$ the tank less might be less
                Shes going to make a killing
                  $60.00 in the summer, $90.00 in winter. gas range, dryer, power vent wh, and old 65% furnace. where is the savings? breid....................
                    Oh we can save her from her gas bill that's not a problem. The problem is, it just wouldn't be legal, and there would be a major fine with it.
                      i ve installed 3 navien tankless in the last 2 years and received a few performance complaints. I just did a fourth one, my house about 2 months ago. Navien NR240A. I needed to know for myself how good is this thing. My family of 6 are giving me feedback on a weekly basis.
                      I revised my sales pitch on tankless as follows:
                      1. I would only get a tankless if you need an endless supply of hot water which applies to big families like mine who take showers and baths close in time.
                      2. When one person is showering and someone else is using hot water in the house, prepare to adjust and correct the water temp immediately. You are really going to feel it. We dont have press balanced valves at our house, maybe thats why.
                      3. expect a 20% or more at times in reduction of water flow
                      4. tracking my gas bill, i used a little more gas than i did last year same time. overall, dont hope for any savings in gas. btw, my hydro is also a little more than last year same time frame.
                      5. lucky i can do it myself for free but a service call every couple of years is good to clean the inlet filter and pump acetic acid to clean the heat exh.
                      6.I mention that a complete install will start at 4500 plus hst. This has been the biggest turn off with selling this unit.
                      7. personally i am happy with our unit because i have never run out of hot water becauce that is the only thing that has made me very happy. Also the boiler room sure looks cleaner and bigger now.
                        is there a way to stop the flow restriction from taking place?
                        A friend is thinking about a propane tankless to preheat water before going through the domestic coil on their oil boiler.
                        The boiler does fine on it's own, but they're wanting to have the boiler run less for domestic only demands.
                        My vote is to just install an indirect, bit they don't want to.
                          If you want to be able to have someone take a shower and use hot water elsewhere at the same time, you need to install a larger unit or two units. Many homes I been in that have more than 2 baths I will recommend to install a pair of the NR98-DVC units. This way when the demand reaches the peak you will not have to make the quick adjustments during the shower.
