Steps to shut water off
  • Steps to shut water off
    Hi fellas,
    i`m going to cut into a water line after the hot water tank to fix a leak and wanted to ask What all I need to shut off?
    Do I need to shut the valve off on the cold water going into the tank or at the meter? Also Do i need to drain the tank a little and turn the temp down on the tank?
    Thx in advance!
    Re: Steps to shut water off
    whole house and the wh. don't let water drop in wh or shut it down. in your case i would shut wh done. if you are lucky that will do it. if not open a hose bib if have one or the faucets and whatnot in house. breid................
