Pex pipe cutters Ratcheting or standered ?
  • Pex pipe cutters Ratcheting or standered ?
    I`m doing a large job in pex and I`m not sure which cutters to get?Anybody have any experience with the two of these? I cant decide on the ratcheting ones over the standered ones.
    Thoughts?
    PC-1375
    http://www.ridgid.com/Tools/PC-1375/EN/index.htm
    RC-1625
    http://www.ridgid.com/Tools/RC1625-P...r/EN/index.htm
    Re: Pex pipe cutters Ratcheting or standered ?
    Both types will work okay. I prefer the non ratchening type like Christy and Pasco sells. I have found they give a more consistant squarer cut also. You just clamp over the tubing and in one action squeaze and rotate the cutter at the same time and your done! In a pinch I will use a pvc ratcheting cutter also if its more handy at the time.
      For PEX pipe, I like the non-ratcheting type. It's a lot faster, and PEX isn't that hard to cut.
        What are the ratcheting cutters like to cut through inch and a half abs? Is it just faster to use a hacksaw?
          I've never used a ratchet cutter on abs, but I think that it would tend to egg shape the pipe instead of make a clean cut like pvc. I just use a plastic saw most of the time. Most track guys would use a ratcheting wheel cutter.
            Thx for the advice
            First round is on me.
