pepperment oil
  • pepperment oil
    Where do I find this , please. Motorhome is a lil stinky. May need
    new toilet wax. Tanks tool ps how much should I use ?
    Re: pepperment oil
    You can buy peppermint oil in the spice/baking section of most any grocery store.
    I normally dump in half a bottle and try to do it in a place where I won't contaminate the environment I'm sniffing in. You also might benefit if you can seal off the roof vents, and plug off the sewer at the front CO. Then pressurize the W&V system using a manometer.
      Re: pepperment oil
      Is your motorhome stinky all the time or just going down the road? Many rv's have and inherent sewer smell caused by the roof vent when traveling. Camping world has two possible solutions that replaces a standard roof vent cap with a vortex style. Hope this helps.
        Re: pepperment oil
        It's been parked for some time. I think the wax doughnut melted in the heat
          Re: pepperment oil
          I had that same problem with mine last yr. I think it had to do with the cold snap and rain then a few days later it went to 100 deg. Those was rings don't all ways do good with quick temp changes.
