Sterling toilet - tank to bowl assy..
  • Sterling toilet - tank to bowl assy..
    Can't find it locally. This is a triangle type assy like the Kohler. Any help would be appreciated. Thanks.
    Re: Sterling toilet - tank to bowl assy..
    Jeff why can't you just use three bolts and a standard sponge gasket I do it with the kohler re builds ?
      Good question. The Sterling is a close coupled design. The 3 bolts go through the gasket assy, which expands when tightened (not needing a bottom nut below the tank). I tried using standard bolts, but the bottom nut hit the bowl. I thought Sterling was made by Kohler and was thinking that the Kohler triangle type gasket assy would work on the Sterling. Not sure about that though. I'd rather use the Sterling kit if possible. Thanks!
        one bolt , one nut , one rubber washer , and one brass washer . Don't know if the tanks are the same to be able to use the same gasket as kohler?
          Kohler gasket will definitely work!
            why waste the time or money ?
              Mansfield gasket might also do it, it you can find one.
