Well Pump hose barb question
  • Well Pump hose barb question
    Hello,
    I am getting ready to install a new 4" Submersible pump in an irrigation well. The pump will be submersed 40' deep. My question is that the pump outlet is stainless steel 1-1/2 NPT, and I need to adapt it down to a 1-1/4 hose barb for the 1-1/4 poly pipe. Is it acceptable to use a PVC bushing to reduce the 1-1/2 to 1-1/4 and then use a brass 1-1/4 hose barb? Should I use teflon tape on all the threads?
    I would prefer to use a 1-1/2NPT to 1-1/4 hose barb in stainless steel, but can't find one locally.
    Thanks
    Re: Well Pump hose barb question
    Sure it's acceptable. You'll need to anticipate issues though, the plastic overtime may become brittle and crack under stress. How about brass bushing ?
      I would like to use brass, but will that cause corrosion issues between the two metals, brass and stainless?
        Originally posted by Jamey View Post
        Hello,
        Thanks
        Why not use a bass bushing? That should be readily available.
        PVC is prone to cracking and I've pulled many a pump that was hanging by wires due to PVC fittings.
        Personal I use a 1 1/4 male x 1 female check valve on every pump. On 1 1/2 outlets sometimes I can find a 1 1/2x1 1/4 but often make due with a line check.
        The check valve built into pumps are usually gravity operated with a metal on metal seal that easily fails with the smallest amount of grit.
        I do not use teflon in wells only recto seal.
          No.
            Thanks for the help.
              Just to clarify btw corrosion between stainless and brass can occur in theory.
              In my experience I've never seen any measurable corrosion between the two metals in a well pump industry and the pump manufactures never make mention of it as a known issue. Stainless steel pumps have a good 25 years in service now so even on pumps that old no issues.
              Brass and galvanized on the other hand. It sucks explaining to a customer the reason you had to pull a pump set 700 feet down after 3 years is because the hack the builder hired didn't know any better and used a brass line check on the galvanized well pipe. The imprints from the 5 story crane used to reach over the house because the builder also lacked the insight to leave access to where the well was behind the house doesn't help much either.
                I wish I took your advise on this, as the internal check valve on the new pump is not working. Rather than pulling the pump, can I just put second check valve where the feed pipe comes into my garage before the pressure switch and tank? The pump is submerged 40', and then it runs about 75' from the pitless adapter to my garage. I'm only using it for irrigation.
                  Yes.
                    Thanks, to everyone, for their help so far!
                    Is there any benefit to having the check valve installed right at the pump? Also, for some reason, whoever plumbed the well into my garage decided to reduce the 1-1/4" poly pipe to a 1" PVC pipe, 4 feet underground, right before it enters the garage through the concrete slab floor. Do you think I will experience more pressure loss with the 1" check valve in the garage than the 1-1/4" valve at the pump?
                    I know the correct thing to do probably is run the 1-1/4" line all the way into the garage, but honestly I am tired of digging at the moment, and the garage is on a slab/no crawl space. It took me a few days of digging up my front yard to finally find the well cap, which turned out to be under my concrete driveway. Why people do things the way they do, I don't know.
                      One inch pipe is perfectly fine, but check valves should be installed at the pump only. If you have problems with water running back, 9 times out of 10 it's not the check valve, it's electrolysis eating galvanized pipes or plastic pipes cracking. The check valve up top, just masks these problems and makes them worse.
                      Frequently asked questions about pumps and tanks.
                        You can get a brass or stainless 1 1/2 mips x 1" PE adaptor. I buy them by the case.
                          A second check valve installed at the pump fixed the problem. Thanks!
