water pipe insulation question
  • water pipe insulation question
    I'm a do it yourselfer and am reinstalling some cpvc pipe in my house. As part of the install, I'd like to wrap the new lines in the installation sleeves to keep the water hotter longer, energy savings, etc.
    I know cpvc has a list of materials where it is not compatible.
    I do not see foam or rubber pipe insulation on the list, but wanted to see if anyone sees any issues
    any thoughts would be appreciated
    Re: water pipe insulation question
    Gitter done!Your good!
    What is rubber pipe?
      Fiberglass insulation is an option too,with a range of wall thicknesses and a nice finished look to it when the proper jackets are used at the fittings,all you need is seam tape,thumb tacks,and a little loose fill insulation for the fittings all available from the manufacturer.
      Steve in the trade since 73 doing new residential/Commercial work
        Rubber insulation, not rubber pipe. Not sure if it's actually rubber, but looks like it (shiny black vs the foam stuff).
          "Fiberglass" forget about it, too expensive.
            Whats wrong with armorflex?
              "armaflex". good stuff, all i use. breid.............
