An issue with snaking Need advise
    Re: An issue with snaking Need advise
    cut or drill out the end of line plug. you're problem is with hardened buildup. combination of the grout/ rust/ debris. with the plug off, you have a straight shot at chopping the stuff out with a pipe and shop vac.
    don't let too much debris fall into the main as it too will collect and need flushing out.
    gal pipe and durham fittings are prone to rust buildup and cholesterol.
      Welcome to the forum Newpl.
      3 years as an apprentice?
      What are your likes and disslikes about your new trade venture.
      What type of install projects are you working on.
      I ask this because it is obvious that your Journeyman has not been teaching you the fine art of drain cleaning.
      So you are in construction?
      I sure hope to hear from you soon.
        Okay it done it was the grout it was lodged in the pipe leading to the wye
        Here are some candy photos
        Here's the topside
        And the bottom.
        And the grout was in the wye .cleaned it
        I was using a bulb I need a spear head in the future .
        This is a job complete
          Yes
          Don't like snaking and digging and dealing with crap
          I know he pretty lazy making all that money on me .
          Machine I was using was pretty new to me
          And with out the proper tools needed it was pretty hard .
          Yes
          No comment .
          But thanks for helping
            I call BS on him being an apprentice. Just look at the fernco 45.
            If he is an apprentice he should know that is not an approved fitting.
              The customer had a limit !
              and I am in apprenceship .
              Thats you opinion !
              Don't bash me because I asked for help from real plumbers on this board .
              The issue is fixed , thanks you for those who's input mattered .
              Remember I'm only an apprentice which means I'm
              Still learning . You have 10 years plus on me I'm not going to argue with that .
                Newpl the fact is you probably spent more on that rubber fitting than a PVC 45 º elbow would of cost you. And since you spent the extra money on that fitting its not to code.
                Personally I would of cut the pipe out of the fitting threads and used a male adapter down low and up at the 45º I would of used a shielded fernco. Also while I was at it I would of installed a clean out tee on the vertical pipe.
                • #23
                  Thanks for that
                  • #24
                    i don't know about the fernco. i don't see it in any of the picks. breid..............
                    • #25
                      Were is there a fernco 45 I been looking at pics for 5 min now
                      SMELLS LIKE $$$$$$ TO ME
                      • #26
                        That picture must have been removed. I won't just make stuff up.
                        • #27
                          I saw it as well. he edited his post before others can make a comment on the poor install. But here it is for you all to see.
                          • #28
                            Thats you opinion !
                            What type of work have you been doing
                            • #29
                              Easy on the Lad. If it's a homeowner, Dr. , it's ok to help ?
                              If It's a female Engineer ,homeowner , You Guys trip over each other ?
                              If it's a guy on his way up in the trade, He's not worthy of Your Help ?
                              • #30
                                I dare not post my hackwork....for the vultures are circling.
