Standpipe and Trap Plumbing code ?
  • Standpipe and Trap Plumbing code ?
    HI! A plumber at home Depot mentioned something about the standpipe being recently update in the plumbing code, is this correct?
    I am renovating a laundry in a building which is going to be fitted with two commercial washing machines and I need to know what height range the standpipe should be from the trap ( Min and Max from trap). and also need to know the distance ( Min and Max ) the trap should be from the floor.
    I need the Canadian OR Quebec, Canada code if possible.
    I am using a 2 1/2 standpipe going into a 2" cast-iron stack. Pic included.
    Paul
    Re: Standpipe and Trap Plumbing code ?
    I doubt that you're using a 2.5" standpipe into a 2" line, sorry.
      Fir 2x4 on concrete! Nice ! in a commercial laundry, no less !
