venting w/cathedral ceilings
  • venting w/cathedral ceilings
    How would you vent a kitchen sink w/ a cathedral ceiling? the sink is on a exterior wall and the upstairs will be a loft, can we tie into the bathroom venting below in the basement? I dont want the pipe visible so I'm really at a loss here. Any ideas would be appreciated. Thanx-DAWN
    Re: venting w/cathedral ceilings
    Install a "Studor Vent" at the kitchen sink p-trap.
    AAV (air admittance valve)
      Bow vent, AAV, exterior wall.....normal vent.
        it's an exterior wall. you can get it in there, just think it through, and have a selection of fittings to make the swings work in the ceiling joist space.
          Before you go the AAV route check with your local codes first. Lots of areas do not allow them. Also warn the home owners their home will stink to all heck at times if you do use an AAV.
            thanx guys for the help-i think we'll run a regular vent with a lot of twists and turns.
